Burning WAV to CD
30 Apr 2007
Kent
Hi Guys,
I've got a WAV file that I've downloaded off of YouTube for my Aunt as her wedding music.
I burnt it to CD and it wouldn't play in my CD player.
I used Sonic.
Is there anything that is fool proof?
Many Thanks
Did you create is as an Audio CD, not a data CD?
If you put the disk back into your PC, do you see the file "Filename.wav" or does it detect it as an audio CD, with "Track 1" etc?
You'll have to ensure you create an Audio CD, which Sonic should do.
Yeah it did burn it as an Audio CD, and it detected as an Audio CD when I put it back in my PC.
Just burnt it using WMP and it works perfectly.
