burning with Nero help - File too big
22 Oct 2008
Lisburn
I've a film I'm trying to burn on Nero 7 but the file won't fit on to the dvd, how do I split it over 2 dvd's?
I'm using 4.7gig +R's
I tried splitting the file in 2 with a bit of software but it kept corrupting the original file. Anyone recommend a good bit of software that would split the file easily enough?
Quality is fine anytime I used it in the past. Failing all else you could just buy some blank dual layer DVD's but I would try using DVD shrink first. It will handle a video of 5.6GB no bother.
If you do use dvd shrink, you can re author the video and lob off stuff at the start/end which will help increase the quality.
