Hi, just built new system... rig in sig.
tested with memtest/prime95, prime, all was ok for 2 hours but i had to end test early. i ocd my xtx with ati overdrive but found it slightly unstable so i reduced mem an core by 10 mhz and that fixed probs i was having hanging in 3d05.
Just been playing BF2 for about 2 hours an the display went all strange.. like loads of blocks, and lines and it froze like that (bit like when a spectrum game loads
). so i powered down and rebooted and got a red message on boot up telling me to hook my gfx card up to the psu, like my gfx card had blown
.. i turned the pc off for 10 mins thinkin the gfx had got to hot but got the same red message again.
So i unplug my xtx from the pci-e slot and also find the power cable that adapts 2 molex connections to 1 pci-e gfx card connection has a brown patch like it has burned.. i plug it back in to the pci-e slot and its ok (used different molex connections this time).. i see the POST screen but i get a message telling my my overclock failed and i have to go into bios setup. Also on POST it seems to search for USB longer than it did... and when i got into windows it installed a couple of devices (forget what now). Now i have reset my overclock on my cpu and gfx and im gonna test it like this.. but anyone have any ideas y this happend? is it my gfx/cpu/mobo or my overclock?
my 3d05 score is back down to 9001 now and im worried somethin is on its way out
any help much appreciated
