Business pc
15 Feb 2011
North Yorkshire
Could the kind people of this forum spec me a pc for work? I need to surf, type docs and perhaps a bit of light gaming. Large storage would be good.
Budget up to £500 I think, no monitor needed going to us old one and get a hazro for gaming I think.
Cheers all
What games do you play? How much of the budget would you like to be used for the graphics card?
It's hard to recommend when It's unsure what sort of gaming it is.
Product Name Qty Price Line Total
Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail Intel Core i3-2100 3.10GHz (Sandybridge) Socket LGA1155 Processor - Retail £94.99
(£79.16) £94.99
(£79.16)
MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** MSI H67MA-E35 Intel H67 (Socket 1155) DDR3 Micro-ATX Motherboard - (Sandybridge) **B3 REVISION** £64.99
(£54.16) £64.99
(£54.16)
Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £41.99
(£34.99) £41.99
(£34.99)
Fractal Design Core 1000 Midi Tower Case - Black Fractal Design Core 1000 Midi Tower Case - Black £27.22
(£22.68) £27.22
(£22.68)
Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) Corsair XMS3 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CMX4GX3M2A1600C9) £25.99
(£21.66) £25.99
(£21.66)
Lepa N-Series 400W Power Supply Lepa N-Series 400W Power Supply £25.98
(£21.65) £25.98
(£21.65)
Sub Total : £234.30
Shipping cost assumes delivery to UK Mainland with:
DPD Next Day Parcel
(This can be changed during checkout) Shipping : £11.75
VAT is being charged at 20.00% VAT : £49.21
Total : £295.26
There's a base to play with. Depending on what card you want to add in. You may need to change the PSU to something better. If you don't care about games, then a 30 quid card will do fine.
I also never added an OS. So if you need that, you can take that into account.
Games wise they would be strategy based.
Thanks for the replies, any more?
Graphics card is purely a choice thing. If your happy on medium settings and you only play once in a while then you could get away with a 50 quid card. If you want high settings and you have a high res monitor. the sky is the limit.
What res do you play at? What sort of quality do you expect? High settings etc?
Just an idea
PSU is totally overkill, but its modular, and only £10 more than the cheapest thing i;d be happy to recommend.
llano onboard graphics will be great for light gaming
YOUR BASKET
1 x AMD Llano A6-3650 2.60GHz (Socket FM1) APU Processor (AD3650WNGXBOX) with FREE DIRT3 PC Game £83.99
1 x MSI A75MA-G55 AMD Hudson D3 (Socket FM1) DDR3 Llano MIcro-ATX Motherboard £71.99
1 x Antec TruePower New Modular 550W '80 Plus Bronze' Power Supply £52.46
1 x Samsung SpinPoint F3 1TB SATA-II 32MB Cache - OEM (HD103SJ) £41.99
1 x Cooler Master Elite 430 Windowed Case - Black £37.99
1 x Kingston HyperX Blu 4GB (2x2GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX1600C9AD3B1K2/4G) £23.99
1 x Samsung SH-S222AL/BEBE 22x DVD±RW SATA Lightscribe ReWriter (Black) - OEM £16.99
Total : £329.40 (includes shipping: FREE).
your only 22 posts away from getting free shipping
Please don't mis understand me, as you can see from my sig I have a fairly powerful machine for gaming at home. At work I should be 'working' however I may need a little light relief, if you get my drift?
Cheers for suggestions.
what type of "work" do you do?
with £500, i would probably get an SB i5 based rig, and spend £100 on the GPU(refurb GTX460)
since gaming would be the most processor intensive thing you would do on the machine then the llano i speced would be more than enough for the job, and its onboard graphics can cope with most games at low to medium graphics. if you want you could also replace the case with a coolermaster silencio for added quietness
