Seeing as there were no relative performance figures for the 20xx vs the 10xx series in non raytracing applications it's a relatively safe bet there arent many architecture improvements on the pixel shader side and the improved 12nm process isnt likely to let them clock much faster. Assuming that how fast are the 20xx cards?
For a while the FLOP calculation for Nvidia GPU's has been
CUDA cores x Clock speed x 2
TITAN V: GPU Cores 5120
1455 MHz (Turbo)= 14.9 TFLOP
1900MHz (overclock) = 19.5 TFLOP
RTX 2080 Ti : GPU Cores 4352
1545 MHz (Turbo)= 13.4 TFLOP
2000MHz (overclock ?) = 17.4 TFLOP
GTX1080 Ti : GPU Cores 3584
1582 MHz (Turbo) = 11.3 TFLOP
2000MHz (overclock) = 14.3 TFLOP
RTX 2080 : GPU Cores 2994
1710 MHz (Turbo)= 10.2 TFLOP
2000MHz (overclock ?) = 12 TFLOP
GTX1080 : GPU Cores 2560
1733 MHz (Turbo) = 8.9 TFLOP
2000MHz (overclock) = 10.2 TFLOP
Keep in mind there's some assumptions going on here but FLOPS generally translate pretty linearly to frame rate within the same general architecture. If i'm right RTX2080 looks like a pretty terrible deal while RTX 2080Ti isnt actually that bad, despite the initial sticker shock.
), drivers may optimise it to gain more and more but I reluctantly say I’m out
. Seems a bit of a waste of resources. Games like that need higher fps and smoother gameplay. I don't spend much time looking down at a puddle for the reflections
