I bought an MSI 290X Lightning (full fat variety not LE) in November but it started "blackscreening" and I had to RMA it. I did ask for a replacement but by the time OcUK agreed that it was faulty there were none of the same cards left and hence I have been refunded instead. This was also around the same time that the 290X Lightning LE jumped in price so I have been holding off ordering that.
I am also reluctant to re-order a card which has already cost me at least 10% of its value to get it delivered and then returned.
However I am keen to upgrade my HD6950 and ideally to stick with AMD as (oddly enough) I do use Tridef on occasion which I understand works best with AMD.
Is the Lightning the quietest of the 290Xs as I found it a bit like a hand dryer when powering the latest games at 1080p and "ultra" settings?
Would there be a better value-for-money upgrade than a 290X?
My budget is probably up to £300 (which was the cost of the 290X Lightning when I bought it).
Any advice would be gratefully received. Thank you.
