Buyer advice, RX580 or RX590
19 Sep 2020
Just thought I'd ask here. Looking at a card for the wife to do some light gaming 1080p or *maybe* 1440p.
Anyone using these here? Are they good enough for 1440p @ 45-60fps, on oldish games is the 590 worth an extra £20 over the 580 and anyone that does use one does it play well with ARK (she loves ARK :rolleyes:).
580 and 590 is basicly the same just the 590 is clocked higher due to better yields on the gpu die. I would look at spending a bit more and going for a nvidia 1660 or a 5600xt would serve you better going forward
Surprised there's any 590s around. But at £150 the 580 is good value imo, 1440p no problem at sub 60fps, settings tweaking will obviously help. The 5500xt is newer but doesn't really boost performance, but comes in at same price. If you're talking £200 ish for a 590 you're nearing 1660super territory which is a solid performer. Also don't have to deal with poo drivers.
