Buying a pre built computer (System Configuration)
19 Jan 2011
I am looking to buy a pre built computer using the system configuruator and this is the base machine i will be using:
http://www.overclockers.co.uk/syscon_int.php?prodid=FS-283-OK
I will be mainly using the system for gaming and a little bit of video editing and I do not need a graphics card as I already have a MSI GeForce GTX 460 HAWK.
Now I do not know which CPU or motherboard I should have, however the rest of the specs I will use are
Case: Coolermaster Elite 335 Case
RAM: Kingston HyperX Genesis Grey 4GB 1600MHz CAS9 Memory Kit
Power supply: OCZ StealthXstream 2 600W Power Supply
HDD: Western Digital Blue 500GB SATA 6Gb/s HDD
OS: Windows 7 Home Premium 64-Bit
thanks
