- 8 Feb 2004
- Dartford, Kent
Hi all,
My sister has just yoinked her M-Audio 2496 back from my computer and i'm in need of buying a new soundcard for recording things with my band.
Simple you might say - buy another 2496.. i didnt really get on with it, found it all a bit shabby and confusing as a mixer was required and there were too many knobs
Been looking at the Emu range, in particular the 1212M as its around the price range i'm looking for and seems to have plenty of ins and outs all built into it.
could anyone give me some advice on whether this is a good card / easy to use etc. etc.
i'll be running Cubase and Pro Tools - so hopefully both of them will be compatible with it.
also, i'll need a pair of monitors to go with the card - so if anyone could give me a hand with some budget ones (ive seen the price of some of the expensive ones ) that will still cut the mustard it would be great!
Thanks
Matt
Thanks
Matt
