Buying a used CPU advice
the thing with eBay (and anything secondhand when PC components are concerned) is how much you can afford to lose if it doesn't work - or works for a while before dying
I bought my old 3500 off of Ebay, worked fine for me. I sold it on again on Ebay and bought my 3700 second hand... Saved a load of money in the process:)
If you must buy one from there, make sure its sold with some sort of guarantee that its working. Theres a lot sold "as seen" or "untested, possibly faulty", so steer well clear of those just in case, especially if you're buying one for about £50-£60 and higher.
