Buying advice, Multimonitor
30 Aug 2020
I'm looking for a new Monitor to use with my DELL Alienware AW2518H 24.5'' 240Hz gsync. The biggest Requierment is compability, there shouldn't be any Problems with the two in conjunction. I used before an old 60hz Monitor and hat stuttering problems.
I use Gsync, and want to avoid Stutters/strange Refreshrate behavior. It is also an Option to use the 2518h as the second one. I use the Mainmonitor mostly for Gaming (also semi competive) and the Dualmonitor Setup for Work/programming, watching stuff while Gaming etcwhat should I buy/consider?
Do I need second one with also 240hz and Gsync?
I also had weird video behaviour on the second screen when running youtube/twitch etc on it and running videogame on my main.
I have never had an issue with running two monitors, so I am more interested in why you did? The greatest problem I had was the poor colour match between the two and I had to buy a calibrator to make them both look the same!
