Buying CPU/mobo combo - need ram & cooler
For RAm you have this to match the colour of your motherboard, or the other one that is slightly faster.
YOUR BASKET
1 x TeamGroup Vulcan RED 8GB (2x4GB) DDR3 PC3-17100C11 2133MHz Dual Channel Kit (TLRED38G2133HC11ADC01) £65.99
1 x TeamGroup Xtreem LV "Frost Edition" 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit £59.99
Total : £134.68 (includes shipping : £7.25).
What case are you going with? Will tell us how much clearance there is (not that it should be a problem as ATX mobo means midi tower so plenty of space). You have a max budget you want to spend on the cooler?
What CPU cooler and 2x4gb ram would you recommend to go with this: -
http://www.overclockers.co.uk/showproduct.php?prodid=BU-006-GI
Nothing fancy just good value. I will try and hit 4ghz with the CPU.
Thanks!
By the time you buy the ram and cooler will be about £340.
Since you are shipping it to france you might be better of buying a full gaming bundle as below *pre-built and tested at 4.2GHz*, all you would have to do is fit the cooler.
ReFlex Gigabyte Z97 - Intel Core i5 4690K @ 4.2GHz Configurable Gaming Bundle-£369.00
http://www.overclockers.co.uk/showproduct.php?prodid=BU-001-OG&groupid=2833&catid=2512
Would save a lot of hassle if a component was faulty on arrival its worth thinking about.:)
YOUR BASKET
How do you sleep at night recommending TeamGroup RAM? lol
That's a good point! Thanks!
YOUR BASKET
I've currently got this case -
http://www.overclockers.co.uk/showproduct.php?prodid=CA-002-XG&groupid=2362&catid=1572
It's not very good and will probably change it later.
