- 3 Jul 2005
Well, I will be buying a dual core amd cpu and im not sure which ones. I will definitely be overclocking, but I dont really want to spend a lot. Is the 3800+ good and can it be overclocked a lot? or would a 1mb cache or 2mb cache make a lot of difference then the 512 cache that comes with the 3800+
thanks
thanks
I would love to go for the Opty 170 but It's out of my budget, so it's between these two. Put it this way, if you were getting both for around the same price do you think the 165 would be the best bet? I've got a SI-120 which I'd be using with it.
