Hiya all, new user looking for some advice on buying my first PC.
First of all what I am hoping to get is a computer that can run the latest games (Crysis, CoD, Aion you know the lot) on fairly high settings. Also would like to be able to use it with 3DS Max, Sony Vegas and get some fairly good render times. I'm not that fussed about the latter though.
£700 is my limit and I don't want to build the computer myself as I know I'll screw it up xD. So I've been looking at the pre-built PC's on the website and the PC Configurator option. I'll put a list of the items I got from the PC config page and hope you guys can give me some advice on alternative components or a cheaper option.
- Coolermaster Elite 335 Case - Black (No PSU)
- Intel Core 2 Duo E8500 LGA775 'Wolfdale' 3.16GHz (1333FSB) - Retail
- Titan TTC-NK85TZ Fenrir CPU Cooler (Socket 754/939/940/AM2/LGA775/LGA1366)
- Gigabyte GA-EP43-DS3 Intel P43 (Socket 775) PCI-Express DDR2 Motherboard
- Kingston HyperX 4GB (2x2GB) DDR2 8500C5 1066MHz Dual Channel (KHX8500D2K2/4G)
- XFX ATI Radeon HD 4890 1GB GDDR5 PCI-Express Graphics Card
- Seagate Barracuda 7200.12 500GB SATA-II 16MB Cache - OEM (ST3500418AS)
- LG GH22NS30 22x DVD±RW SATA Dual Layer ReWriter (Black) - OEM
- OCZ ModXStream Pro 600w Silent SLI Ready ATX2 Modular Power Supply
- Onboard Sound Card (ZERO COST)
Total cost: £651.24
So one thing I was wondering is that should I go for the THIS processor over the duo core? I noticed I'd be getting more hertz(correct term? =P) with the duo and more cache but the does the extra 2 cores make up for this loss, or am I better off scrapping intel and going for the AMD Tri
Also is the power supply going to be enough to support all of these components or should I choose one with a bigger bite?
And if theres anything else that looks bad in the build please tell me, adn heres the link for the PC config page.
Many thanks!
Edit: I don't plan on overclocking it.
Total cost: £651.24
Many thanks!
