Buying new monitor?
19 May 2009
Ive been using a 17 inch dell monitor for about 4 years now and I know it just doesn't do it in games anymore im sick of being pixel sniped and having no idea where from. I have around 110 quid to spend and am looking for a decent cheap monitor nothing less than a 22, I was looking at the older 2232 samsungs or this acer?
What do you recommend any help welcome?
Right link gone and ive just won a Samsung 2232BW 22" on ebay not the newest but compared to the old dell 17 inch hopefully it will be a lot better.
Glad I could help, it wasn't bad years ago when everyone had 15 and 17 inch monitors but know that 22 24 inch monitors are so cheap everyones got one and its makes it harder for us on the smaller tft's.
i have a benq monitor but not the one ocuk sell.
i have this one BenQ G2420HD Widescreen Monitor 24.0 inch (1080i/1080p) TFT LCD 1000:1 300cd/m2 (1920 x 1080) 5ms D-sub/DVI-D/ HDMI 1.3/Headphone Jack (Glossy Black).
this can be had for £155 from elsewhere.
- Screen Size: 24" Widescreen
- Resolution: 1920x1080
- Contrast Ratio: 5000000:1
- Brightness: 250cd/m²
- Response Time: 5ms
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- VESA Compliant
- Dimensions: 570.0mm x 412.6mm x 183.9mm
this is the ocuk benq.
this is the other benq.
Monitor BenQ G2420HD 24in Display Area - 53.14 x 29.89cm
Screen Type TFT LCD 16.7 million Colours
Aspect Ratio 16:9
HD Support Yes
Resolution (Native) 1920 x 1080 Pixels HD 1080p
Brightness 300cd/m2
View Angle 170° (Horizontal - Max) x 160° (Vertical - Max)
Contrast Ratio 1,000:1 (Static) , 40,000:1 (Dynamic)
Response time 5ms
Scan Frequency 24 to 83KHz (Horizontal) x 50 to 76Hz (Vertical)
Tilt (Forward/Backward) Up 20°, Down 5°
Pixel Pitch 0.27mm
Video Bandwidth 205MHz
Interfaces/Ports
VGA In 1 x 15-pin D-sub
Digital In 1 x DVI-D (with HDCP)
HDMI Ports 1 x HDMI 1.3
Headphone Ports 1 x Headphone Port
System
Language Selection 17
System Requirements
Operating Systems Supported Microsoft Windows Vista Premium
Electrical
Power Consumption 49W (Max) / <1W (Saving)
Power Supply Built-in
Physical
Display Type BenQ G2420HD LCD Display
Case Colour Glossy Black
Wall Mount Yes , VESA Compliant - 100mm x 100mm
Dimensions 57.0cm (W) x 18.39cm (D) x 41.26cm (H) - Weight 4.9kg
# BenQ G2420HD Widescreen Monitor
# 24 inch TFT LCD Screen
# Maximum Resolution: 1920 x 1080 (1080i/1080p)
# Brightness: 300 cd/m2
# Contrast Ratio: 1000:1 (Dynamic Contrast Ratio 40000:1)
# Response Time: 5 ms (2ms Grey To Grey)
# Input connector: D-sub / DVI-D / HDMI 1.3 / Headphone Jack
# 16.7 Million Colours
# Senseye+Photo Image Technology Brings You the Most Optimized Images: BenQ’s exclusive Senseye technology gives you preset modes Standard, Dynamic, Movie, Photo that provide instant optimized settings for different usage scenarios. Senseye+Photo is an enhanced version that adds support for the industry-standard sRGB colour space, allowing you to obtain consistent results when you view and manipulate images on a G Series monitor and on other sRGB-compliant devices
# 40000:1 DCR (Dynamic Contrast Ratio) Offers you the Finest Details: With a dynamic contrast ratio of 40000:1 to give you splendid image details and clarity in darkened and complex motion pictures: everything becomes more vivid! The 40000:1 DCR automatically adjusts backlight to optimize light levels for each and every scene, and flawlessly renders dark details. This makes movies and video games more enjoyable
# RoHS Compliance: BenQ do care about our living environment; all BenQ LCD monitors have RoHS certification (Restriction of the use of certain Hazardous Substances) The RoHS Directive stands for the restriction of the use of certain hazardous substances in electrical and electronic equipment. This Directive bans the placing on the EU market of new electrical and electronic equipment containing more than agreed levels of lead, cadmium, mercury, hexavalent chromium, polybrominated biphenyl (PBB) and polybrominated diphenyl ether (PBDE) flame retardants
# AMA (Advanced Motion Accelerator) gives you true-to-life images with enhanced picture quality and reduced visual noise with only 2ms GTG (Grey to Grey) response time so there’s no delayed response to image deliverance
# Colour temperature: Reddish/Normal/Bluish + user mode
# Glossy Black colour
I'm interested in that monitor! Do you own one? Why do you recommend it?
No, i don't own it. I have a HP LP2475w which costs £460 :eek:
I just saw this being advertised yesterday, and it looks great and at a great price too. I would buy one of these if i was after a 24" monitor, actually, I might still buy one later.
ive got this one BenQ G2420HD and cant really fault it.
i changed from a dell w1900 and this is so much cleaner and sharper than the dell.
