Buying nvme hard drive.
22 Jun 2018
Hi
I have a GIGABYTE motherboard - https://www.gigabyte.com/Motherboard/X570-GAMING-X-rev-10#kf
I'm wondering if this NVME hard drive will fit and work - https://www.overclockers.co.uk/team...pcie-4.0-solid-state-drive-sto-tmg-03127.html
Yeah that's an NVME slot and that drive will work fine.
The primary nvme slot is under the heatsink above the graphics card slot. Use that one first if you haven't already.
It'll work fine, there's a slot directly above the top X16 slot/below the CPU socket also if you weren't aware, there's a heatsink/panel covering it that you can access by removing the screw.
thanks for the help guys wont be buying the hard drive for a few more weeks.
Might need to take out the graphics card to get access to it.
David
