- 23 Nov 2009
Hello,
After much pondering and advice from here, I have fibnally decided to plump for a couple of R9 290's over 2 780's.
However, I heard the R9's run pretty hot so need non-reference models for better cooling if I'm not mistaken.
As I use an ASUS P9X79 mobo, I don't think the bottom PCI-E slot is going to take a cooler bigger than a slot (so whole card takes up 2 slots) without it hitting my case.
Therefore, what would yu guys recommend? Was looking at the Sapphire Tri-X's.
Have also heard the R9's are a little hit and miss - would that be enough reason to turn to the Green side or have these issues been fixed and remain proudly Red?
Thanks in advance!
Thanks in advance!
