Hello!
I recently noticed that my right hand speaker is quieter than the left. It's a cheap logitech 2.1 system (model z313 I think).
I swapped the speakers from an identical set, and the problem persists. I couldn't swap the sub over.
I changed the input from rear on PC, to front audio on the case, and the problem persists.
When I plug the speakers into my phone the problem goes away! This is without moving the speakers or cabling..
I guess the audio part of my motherboard must be dying? So perhaps a PCI sound card would remedy the issue?
Thanks!
Paul
Thanks!
Paul
