Hi all,
Since weekend I have noticed that there is some sort of weird buzzing/static noise coming out of my headphones (like a long beeeep and crackling which changes in intensity), which was not there before. I have built this pc in November 2019. I have tested it with different headphones cord, same issue, however when i plugged my headphones into my SO's laptop, noise wasn't there anymore, therefore i believe this is not an issue with headphones, but rather with my motherboard. Also, these noises start as soon as you power on pc. The sound is mostly noticeable in quiet environment, or when gaming at night. Front jack works fine. Issue is only with the rear jack.
So far I have tried the following to fix it but nothing helped:
- Updated Realtek drivers
- Used different headphones and the noises persisted
- Disassembled pc and rebuilt it again. Resitted Io shield and checked all cable connections
- tried using ground loop isolator but it made things worse, sound went really quiet and one headphone did not work at all. It is an interesting finding as people are suggesting that it may be issues with jack ground, because if the ground was there, the isolator would have worked as intended.
- Changed power cord
- Changed power strips
- Took pc to different room to test other wall sockets in house
I am running out of options on how to fix this. Please can someone help me as this issue is driving me crazy.
PC Spec:
Motherboard: MPG Z390 Gaming Edge AC
CPU: intel i7-9700k
RAM: Vengeance LPX 16GB (2x8GB) DDR4 3200MHz C16
GPU: 2070 Windforce 8GB
SSD1: 860 QVO 1TB
SSD2: 120GB KINGSTON HYPERX 3K SSD
HDD: 2TB 3.5" SATA-III 6GB/s HDD
PSU: Corsair 750W CS Series Modular 80 Plus Gold
Headphones: ATH-M50X
PC Spec:
CPU: intel i7-9700k
SSD1: 860 QVO 1TB
