- 5 Feb 2009
When I got my GTX 780 the other week, I thought there was some fairly minor buzzing coming from it that I could hear when it was being stressed.
I've noticed, however, that whilst there is some buzzing coming from the card itself, this is only actually audible if I put my ear near to the case under the desk. From my seat it's completely inaudible. What I was hearing was buzzing coming through my speakers.
Because the speaker volume was low initially when I was testing the card I just put it down to minor electrical buzz I've had on a couple of cards and that seems to settle down with use. When playing Tomb Raider, though, and turning the volume up I noticed the buzzing increasing with the speaker volume to the point it became unbearable at decent volume levels for immersive gameplay.
There's no buzzing when I use my USB headset, and I can cure the issue if I unplug and plug the speaker cable into my sound-card output a few times. It's a bit hit-and-miss, but I can usually make it go away with a bit of fiddling with the connection.
Any ideas what might be causing this? It didn't happen with my old GTX 670, so I'm inclined to think it is some sort of electrical interference from the graphics card.
My speakers are quite old Videologic Sirocco Spirits plugged into an equally old Creative Soundblaster Audigy 4.
