Bykski Distroplate..
27 Jul 2025
Uk
Hi ,very new to custom watercooling, I have a bykski distroplate to fit my Thermaltake p7 case, the Bykski website stated that any DDC pump will fit ,I purchased the one I was advised to buy by Watercooling UK ,but the mounting holes are no where near , the pump is square and the mounting holes are in a rectangle ??. Can any one help me please..?
I could be remembering this all wrong so wait for further confirmation but don’t you remove the pump from the housing it comes in and fit the pump directly into the distro plate (apologies if I’ve mis-remembered!)
Also - you need to remove the competitors name from your post.
Contact the place you bought it from and ask for their guidance? Seems a bit shoddy for them to leave you high and dry after you buy.
A picture of the pump area on the distro plate would be helpful. I was under the impression all DDC-style pumps where a standard size (square screw hole pattern).
Edit: Is it the RGV-TT-P7-P that you have? From a random Google search I can see the marketing blurb states it uses a DDC pump, but the images seem to show a D5-style pump attached with a spacer. It does look to be a square mounting pattern though so it's possible either would fit, it's difficult to tell without measuring.
