C and C++
15 Mar 2008
Trying to teach myself C++ and running into a few questions so I thought maybe some of you guys could help me out here :)
I come from a C# background so some of the syntax is rather familiar(obviously), in fact I think the biggest learning curve is learning what libraries I need to include for the purposes I need!
Anyway my question is, can I use a C header file in C++? More specifically could I simply include http://developer.spotify.com/en/libspotify/overview/ in a C++ project and it would just simply "work"? Or do I need some sort of wrapper for it?
Ideally it should work fine. Since C++ runs off the .NET framework all the libraries you will ever need should be included.
This could be somewhat different however if you're writing for linux.
Had some problems getting this to work in C++, but I put it down to my inexperience :p
So I tried getting it working in C thinking it would all slot together a bit smoother, however I now get compilation issues to do with things within their library.
This is harder than I thought it was going to be ;)
I only started using/learning c++ about a year and a half ago, coming from a 4 year C# background, so I kinda know the situation your in.
I would be happy to help if I can :)
Really appreciate the offer thanks :)
When I get home I'll post the code I've got so far, I think the main issue I have is with the function pointers. I believe they are the equivalent of delegates and events in .NET. The issue appears to be that they are not "firing" or at least If they are I cannot seem to get them to hit break points.
Anyway I think it will be all clearer once I post some code up tonight :p
Better late than never ;) and I'm still stumped.
Code:
#include <cstring>
extern "C" {
	#include <libspotify/api.h>
#include <stdint.h>
#include <iostream>
using namespace std;
const uint8_t g_appkey [] = {
/*api key*/
const size_t g_appkey_size = sizeof(g_appkey);
static sp_session *session;
static void (SP_CALLCONV logged_in)(sp_session *session, sp_error error)
	if(error != SP_ERROR_OK)
		cout << "Error on log in\r\n";
	else
		cout << "Logged in\r\n";
static void (SP_CALLCONV logged_out)(sp_session* session)
static void (SP_CALLCONV connection_error)(sp_session *session, sp_error error)
static void (SP_CALLCONV notify_main_thread)(sp_session *sess)
static sp_session_callbacks sessionCallbacks = {
	&logged_in,
	&logged_out,
    NULL,
    &connection_error,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL,
    NULL
static sp_session_config sessionConfig = {
		SPOTIFY_API_VERSION,
		"/tmp",
		"/tmp",
		g_appkey,
		g_appkey_size,
		"Test Client",
		&sessionCallbacks,
		NULL,
		TRUE,
		FALSE,
		TRUE
int main() {
	cout << "Hello World";
	sp_error err;
	err = sp_session_create(&sessionConfig, &session);
	if(err != SP_ERROR_OK )
		return -1;
	else
		sp_session_login(session, /*username*/, /*password*/, 1);
		sp_session_logout(session);
	string str;
	cin >> str;
	return 0;
Now if I put a break point on:
Code:
It never hits the break point which leads to me believe that it isn't hitting that block for whatever reason.
With out knowing anything about the api, my guess would be that sp_session_login doesn't block so you have to wait for the login process to complete.
e.g.
Code:
bool gbLoginError = false;
volatile bool gbLoginCompleted = false;
        gbLoginError  = error != SP_ERROR_OK;
	gbLoginCompleted = true;
int main()
                while(!gbLoginCompleted)
                         Sleep(0);
                if(gbLoginError)
	        else
(completly untested)
Thanks for the tip I'll give it a whirl!
Doing some more reading and the library isn't thread safe in parts, which I had not realised. I need to pay more attention :p
So the way I seemingly hook up to the function pointers is fine?
