C++ and OpenGL problem
7 Nov 2007
Required
Hi there,
Working through Beginning OpenGL Game Programming and I want to add a TGA mouse cursor. Most of it is sorted, but there's a problem I'm having.
winmain.cpp has the mouseX and mouseY variables. I have taken these out of the winmain.cpp file and put them in a header called mouse.h which I have included at the top of the file. All hunky dory.
Now, I want to use the same mouseX and mouseY variables in another file. Can I do this? Do I need to have a separate routine to find the mouse's X and Y values in CGfxOpenGL.cpp? Using mouse.h gives me this:
error: 'mouseX' was not declared in this scope
error: 'mouseY' was not declared in this scope
Not sure what to do here guys? :)
Got it working now! Declared them as external variables in the header file:
extern int mouseX, mouseY;
Then in winmain initialised them equal to 0.
Now to find out how to get this cursor transparent...
If i'm reading your problem right what you should do is:
Write an accessor/mutator for mouse x and y, then simply create an instance of your 'mouse' class in the class you want to use those variables in.
So basically:
private float _mouseX, _mouseY;
void SetMouseX(float mouseX)
_mouseX = mouseX;
float GetMouseX()
return _mouseX;
(you should probably return by const reference with the getter ^^).
Then where you want to use them just make a new instance of mouse (i.e Mouse _mouse) then you can do _mouse.setMouseX etc.
Thanks for that. I'm a little confused at the minute, coming from C to C++ means I haven't fully grasped things yet. Probably sleep on it and come back to it in the morning.
Cheers anyway! :)
