Been struggling to get my head around this one. I have a hierarchy of Term objects that I want to iterate through and add to an asp menu control. I think my recursive function is fine except that each time I need to add the child items to the corresponding parent item, then add the full structure to a navigation control.
See code:
The line myMenu.Items.Add is the problem as this will result in only a 2-level navigation structure. Instead what I need is to be able to add child nodes to the corresponding parent node so that I have maybe 4 or 5 levels deep.
What am I missing here? I could maybe use something like myMenu.Items[0].ChildItems.Add but I have no idea where to get the index value from that would drive this.
Any help would be great.
See code:
Code:
private void IterateSubTerms(Term t)
if (t.Terms != null)
foreach (Term term in t.Terms)
MenuItem childItem = new MenuItem();
childItem.Text = term.Name.ToString();
childItem.NavigateUrl = "default.aspx";
// next line is the problem
myMenu.Items.Add(childItem)
IterateSubTerms(term);
