7 Mar 2010 at 17:18 #1 BenJ BenJ Associate Joined 10 Aug 2006 Posts 704 Location Warrington As above, does it work folks? win 7 64bit
7 Mar 2010 at 17:19 #2 ns400r ns400r Soldato Joined 23 Apr 2004 Posts 3,579 Location UK, Near the middle...... Yep, works fine.
7 Mar 2010 at 17:24 #3 BenJ BenJ Associate OP Joined 10 Aug 2006 Posts 704 Location Warrington ns400r said: Yep, works fine. Click to expand... Oh goodie, i know it wouldnt work when i had vista 64 bit. I'm going to install it now with zero hour, havent played it in yonks!
7 Mar 2010 at 17:47 #4 altich88 altich88 Associate Joined 28 Oct 2008 Posts 233 I had a bit of a problem getting it to run on 64-bit 7 at first, turned out to be a problem regarding "options.ini". http://forums.cncnz.com/index.php?showtopic=12319 Hope you don't need it though ^^
7 Mar 2010 at 17:48 #5 SilverTongue SilverTongue Associate Joined 4 Jun 2007 Posts 2,292 Location South Wales never had any problems myself both generals and zero hour
7 Mar 2010 at 18:14 #6 BenJ BenJ Associate OP Joined 10 Aug 2006 Posts 704 Location Warrington The options.ini file worked a treat, all up and running now. Thanks
7 Mar 2010 at 22:10 #7 barmyllama barmyllama Man of Honour Joined 20 Dec 2004 Posts 7,649 Location Tamworth Worked on Vista 64 for me so should work ok, not tried it on Win7 yet.
