26 Apr 2012 at 17:16 #1 Arnie Arnie Permabanned Joined 8 Dec 2010 Posts 707 Location The Choppa! C&C games from 1 to Zero Hour - will they work on Win 7 x64?
26 Apr 2012 at 17:18 #2 Mak3R Mak3R Associate Joined 26 Feb 2009 Posts 2,331 Location Norn Iron I know zero hour does as I have it installed. Cant say anything for the older ones.
26 Apr 2012 at 18:19 #3 chrismscotland chrismscotland Man of Honour Joined 16 Jul 2009 Posts 9,650 Location Edinburgh I've had Red Alert 2 running fine and I believe theres a patch to allow the older ones to work too, they didn't out the box.
26 Apr 2012 at 19:04 #4 linktoinsanity linktoinsanity Man of Honour Joined 5 Oct 2008 Posts 9,009 Location Kent Yes. They do work. With the following patches/fixes: http://www.commandandconquer.com/forums/showthread.php?547-Common-Problems-(Updated-11-12-2011)
26 Apr 2012 at 19:34 #5 Arnie Arnie Permabanned OP Joined 8 Dec 2010 Posts 707 Location The Choppa! linktoinsanity said: Yes. They do work. With the following patches/fixes: http://www.commandandconquer.com/forums/showthread.php?547-Common-Problems-(Updated-11-12-2011) Click to expand... Great link, thanks.
26 Apr 2012 at 23:17 #6 linktoinsanity linktoinsanity Man of Honour Joined 5 Oct 2008 Posts 9,009 Location Kent Arnie said: Great link, thanks. Click to expand... No worries. Probably the best place for information on The First Decade around.
26 Apr 2012 at 23:28 #7 opstrat opstrat Soldato Joined 26 Aug 2010 Posts 3,516 Location glasgow red alert is going free. but wont run on windows 7. nor will compatible mode. the setup files wont even run. http://compactiongames.about.com/od/freegames/p/ccredalert_free.htm
26 Apr 2012 at 23:33 #8 Aeleys Aeleys Soldato Joined 25 Aug 2010 Posts 5,217 red alert 2 working fine here, not sure bout the rest
