Do you want to print a number out in binary?
I don't think there is anything in the C library to do that, but it's not too hard to do yourself. Basically you just have to check if the number is even or odd, if it's even concatenate "0" onto the end of the string, if it's odd concatenate a "1". Then left shift your integer by 1 (equivalent to dividing by 2). Repeat until your integer is equal to 0.
You need to be a little careful with the order you do things in; this will print the binary in little-endian bit order (backwards)![]()
