- 20 Nov 2008
Hey guys/ gals...
Have a problem with my laptop... it is a dell inspiron 1721..
Am running a dual boot setup between Windows Vista (drive R) and windows 7 (drive c). There is another hard drive which is just being used as a storage drive.
My problem is that the computer will boot into both operating systems fine but when i come to browse the c drive or relative c drive for each op i get the C drive is unavaliable, due to network problems...
This problem is also affecting all the software and all the system tools so i can't do a restore or a backup or anything.
I can browse my documents but the files don't open.
Have tried using safe mode and the system restore on the disks. Also the system restores / startup fixes on the install disks.
I have also tried to perform virus scans but i can't get to the software to scan. tried to download a registry cleaner but the temp folder is stuck on the c drive.. even when moved to the storage drive it keeps refering to the c drive.
any ideas on fixes?
Thanks
Derrick
any ideas on fixes?
Thanks
Derrick
If you're using an Administrator account you should be able to Take Ownership or modify the Permission List.
