c++ easywin applications
1 Dec 2004
S.Wales
Is it possible to create C++ easywin applications on C++ builder?
I need a free proggy (preferably borland) that will let me do this to enable me to do my uni work at home....
there must be someone who knows this????
Iv posted a number of threads in this forum that are simple questions, yet no one replys.. I see other threads by other people that are more complex questions which yield several replys..what is going on??
iv installed compiler but i cant find it in my programme list???
its no use, i cant do any work at home :(
can i create easywin applications with c++ builder?
happytechie said:
the compiller will be a command line jobby and won't ahve an entry in the programs menu:
did you try my sugestions in the thread here:
http://forums.overclockers.co.uk/showthread.php?t=17532611
what exactly do you mean by easywin applications?
HT?
The programme we use in uni (borland c++ 5.02 or 5.05) when you create a new project, you have the option to create an easywin application which is what we are using..
I can also use a console application (dos) iv tried creating this in c++ builder but i just get error messages when i try to compile and run..
have you tried emailing your lecturer for how to get it set up at home? it's possible they have a copy they can give to students, much like microsoft's academic alliance?
Right then, I've never used borland C++ builder so I can't help you with the 'easywin' application. VIsual Studio does have a simpilar 'new application wizard' type of thing but it won't edit the files for you. what I would sugest (if you can't get hold of the IDE you are using at school, at home) is that you create your 'easywin' application, save all the files to a memory stick / zip + E-Mail / CD-Rom / floppy disk and take them home. This should be able to be built by a command line command to the borland compiler.
what error messges are you getting? What command are you issueing? What files have you got in your project?
HT
