Straight to the question:
Have used VB since 1992, from V1 through to .Net Framework 3
Have used C# on and off for about 2 years although nothing major.
C#: I can get by on the syntax, I can go through the logic of a program, I can see what it's trying to achieve.
What I can't do however is understand about Public/Private/Global variables, some dedicated commands that I'd use often in VB like "InStr", "Split" and don't really feel confident in navigating Table Adapters like I am in VB.
I'm starting to edge towards 'desperate' in moving from Swansea back to London, and the latest job search for jobs with my skills WITHOUT C# yeilded about 5 results this week!
So...
How long do you think it would take for me to reach a more proficient level of C# based on my current experience with the language and past record?
I just want a prospective employer to say "OK well he's got over 15 years in VB, 10 in SQL, not done much in C# but he should be able to do it no probs"
Any thoughts?
So...
Any thoughts?
