C Help - Nested Loops
14 Jun 2009
Hi,
I'm new to C and struggling quite a bit with the following.
I need to draw the following:
I've managed to draw a 5 x 4 grid of *'s using the following:
PHP:
#include <stdio.h>
int main(void)
  int row;
  for (row = 0 ; row < 4 ; row++)
      int column;
      for (column = 0 ; column < 5 ; column++)
	  printf("*");
      printf("\n");
  return 0;
I know I almost certainly need another nested loop somewhere but I really have no idea where to start if i'm honest :(
Any help is appreciated.
You don't need another loop. You could change the printf("*") line to include an if, and only print a "*" if it's one of the edges (i.e. col is 0 or 4 or row is 0 or 3), and print a space otherwise.
+1 Swanster.
Please indent your braces for your second for loop o.O
Had a go:
please bare in mind I've never used C, only C# and C++, so if my syntax is incorrect, apologies.
Code:
#include <stdio.h>
int main(void)
	int row;
		int column;
			if (row == 1 || row == 2)
				if(column == 1 || column == 2 || column == 3)
					printf(" ");
				else
					printf("*");
			else
			printf("*");
	printf("\n");
return 0;
Could have used < and > on the second if, but cba to change it now.
