A noob C++ question for you. This is a very simple C++ program (well it doesn't actually do anything!). When I try and compile I get the error:
test.hh:14 error: ISO C++ forbids declaration of `map' with no type"
Can anyone explain to me why I cant put a map as a member variable in the header? If I write that line within a method body in the .cc file it works fine, but I need it as a member variable.
test.hh
test.cc
test.hh
Code:
#include <map>
#include <string>
namespace TestMap
class MapTester {
public:
MapTester();
void TestMap();
private:
map<int,int> test;
test.cc
Code:
#include "test.hh"
using namespace TestMap;
using namespace std;
MapTester::MapTester()
void MapTester::TestMap()
int main()
