C++ help
30 Aug 2009
one nation under sony
Code:
// transform_XG.cpp : Defines the entry point for the console application.
#include "stdafx.h"
#include <math.h>
#include <stdlib.h>
#include <stdio.h>
#include "glut.h"
#define KEY_UP 101
#define KEY_DOWN 103
#define KEY_LEFT 100
#define KEY_RIGHT 102
int tx=0, ty=0;
float sx=1.0, sy=1.0;
float theta=0.0;
void letter_A()
  	//glColor3f (1.0, 0.0, 0.0);	       // set line colour red
	float red, green, blue;
glClear(GL_COLOR_BUFFER_BIT);
red = float(rand()%255)/255.0;
	green = float(rand()%255) / 255.0;
	blue = float(rand()%255) / 255.0;
	glColor3f(red, green, blue);
	glLineWidth(5.0);		// set line width
	 glBegin(GL_LINES);	// beginning of drawing
		glVertex2i(160, 500);
		glVertex2i(250, 75);		// left side line
		glVertex2i(75,75);
		glVertex2i(160,500);		// right hand side line
				// finishing drawing.
		glVertex2i(95, 180);
		glVertex2i(225, 180);
	glEnd();
void letter_S()
  	//glColor3f (0.0, 1.0, 0.0);	       // set line colour red
//glClear(GL_COLOR_BUFFER_BIT);
	glLineWidth(5.0);		// set line width or add more line styles
	 glBegin(GL_LINE_STRIP);
		glVertex2i(600, 500);	// link most lines together
		glVertex2i(400, 500);
		glVertex2i(400, 300);
		glVertex2i(600,300);
		glVertex2i(600,100);
		glVertex2i(400, 100);		// last line
		glEnd();
void display()
	glClear (GL_COLOR_BUFFER_BIT); // clear screen
	glPushMatrix();
		glTranslatef(tx,ty,0.0);
		letter_A();
	glPopMatrix();
	glPushMatrix();
		glScalef(sx,sy,1.0);
		letter_S();
	glPopMatrix();
	glPushMatrix();
		glRotatef(theta , 0.0, 0.0, 1.0); 	// rotate around origin
		letter_A();
		letter_S();
	glPopMatrix();
	glFlush();
void myKeyboardFunc (unsigned char key, int x, int y)
	switch (key) {
	case '8':
		tx = tx + 0;
		ty = ty + 100;				//Move A upward.
		glutPostRedisplay();
		break;
	case '4':
		tx = tx - 100;
		ty = ty + 0;				//Move A upward.
		break;
	case '6':
		tx = tx + 100;
		break;
	case '2':
		tx = tx + 0;
		ty = ty - 100;				//Move A upward.
		break;
	case '9':
		tx = tx + 100;
		break;
	case '7':
		tx = tx - 100;
		break;
	case '1':
		tx = tx - 100;
		break;
	case '3':
		tx = tx + 100;
		break;
	case 't':
		sx = sx*0.90;
		sy = sy*0.90;			// scale S around origin (0,0)
		break;
	case 'g':
		sx = sx*1.1;
		sy = sy*1.1;			// scale S around origin (0,0)
		break;
	 GLvoid window_special_key(int key, int x, int y)
  switch (key) {
	case KEY_RIGHT:
		theta=theta-1.57; 		//rotate right-hand-side by 45 degrees.
		break;
	case KEY_LEFT:
		theta=theta+1.57;		 //rotate left-hand-side by 45 degrees.
    		break;
  	default:
    		printf ("Pressing %d doesn't do anything.\n", key);
    		break;
	case 27:			// Escape key
		exit(0);
		break;
void init (void)
/* select clearing color 	*/
   glClearColor (0.0, 0.0, 0.0, 0.0);
/* initialize viewing values  */
   glMatrixMode(GL_PROJECTION);
   glLoadIdentity();
   gluOrtho2D(0.0, 700.0, 0.0, 800.0);
int main(int argc, char** argv)
   glutInit(&argc, argv);
   glutInitDisplayMode (GLUT_SINGLE | GLUT_RGB);
   glutInitWindowSize (700, 500);
   glutInitWindowPosition (100, 100);
   glutCreateWindow ("Drawing Letters AS");
   init ();
   glutDisplayFunc(display);
   glutKeyboardFunc(myKeyboardFunc);
   glutSpecialFunc(& window_special_key);
   printf("Press \n's' to scale S around (0,0), \n't' to translate A.\n\n");
   glutMainLoop();
   return 0;   /* ANSI C requires main to return int. */
I'm trying to get the letter A to move in 8 directions and the letter S to scale
It worked but then I implemented rotation for both letters and now it doesn't.
don't know how to re-enable it
thanks in advance
EDIT:
lol I fixed it by commenting out
//glColor3f(red, green, blue);
