C# learning and getting in to a right pickle ..
8 Mar 2005
London, UK
So I have been mucking about with the CU tutorial and am now attempting to mimic the CourseAssignment step using a dB generated primary key for the CourseID value instead of user defined one.
So in my example,
Student=Applications
Course=IndApp (individual applications)
CourseAssignment=AppAssignments
In effect; Applications is the solution name, where IndApp contains separate vendor applications presented to the solution.
However; when I attempt to seed the database it throws a wobbly. The error may appear pretty self-explanatory but I'm at a loss where to start.
As far as I can fathom; the AppAssignments table is created correctly and my classes are set correctly. Any pointers would be most welcome.
Code:
SELECT [t].[ID] FROM [Application] t
INNER JOIN @inserted0 i ON ([t].[ID] = [i].[ID])
ORDER BY [i].[_Position];
Microsoft.EntityFrameworkCore.Database.Command:Information: Executed DbCommand (8ms) [Parameters=[@p0='?' (Size = 50), @p1='?' (Size = 50)], CommandType='Text', CommandTimeout='30']
SET NOCOUNT ON;
INSERT INTO [IndApp] ([Application], [Version])
VALUES (@p0, @p1);
SELECT [ID]
FROM [IndApp]
WHERE @@ROWCOUNT = 1 AND [ID] = scope_identity();
Microsoft.EntityFrameworkCore.Database.Command:Information: Executed DbCommand (1ms) [Parameters=[@p0='?' (Size = 50), @p1='?' (Size = 50)], CommandType='Text', CommandTimeout='30']
SET NOCOUNT ON;
VALUES (@p0, @p1);
SELECT [ID]
FROM [IndApp]
Microsoft.EntityFrameworkCore.Database.Command:Information: Executed DbCommand (0ms) [Parameters=[@p0='?' (Size = 50), @p1='?' (Size = 50)], CommandType='Text', CommandTimeout='30']
SET NOCOUNT ON;
VALUES (@p0, @p1);
SELECT [ID]
FROM [IndApp]
Exception thrown: 'System.InvalidOperationException' in Microsoft.EntityFrameworkCore.dll
'iisexpress.exe' (CoreCLR: clrhost): Loaded 'C:\Program Files\dotnet\shared\Microsoft.NETCore.App\2.2.3\System.Diagnostics.StackTrace.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'iisexpress.exe' (CoreCLR: clrhost): Loaded 'C:\Program Files\dotnet\shared\Microsoft.NETCore.App\2.2.3\System.Reflection.Metadata.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
'iisexpress.exe' (CoreCLR: clrhost): Loaded 'C:\Program Files\dotnet\shared\Microsoft.NETCore.App\2.2.3\System.Text.Encoding.Extensions.dll'. Skipped loading symbols. Module is optimized and the debugger option 'Just My Code' is enabled.
Tracker.Program:Error: An error occurred while seeding the database.
System.InvalidOperationException: The instance of entity type 'AppAssignment' cannot be tracked because another instance with the same key value for {'IndAppID', 'ApplicationID'} is already being tracked. When attaching existing entities, ensure that only one entity instance with a given key value is attached. Consider using 'DbContextOptionsBuilder.EnableSensitiveDataLogging' to see the conflicting key values.
   at Microsoft.EntityFrameworkCore.ChangeTracking.Internal.IdentityMap`1.ThrowIdentityConflict(InternalEntityEntry entry)
   at Microsoft.EntityFrameworkCore.ChangeTracking.Internal.IdentityMap`1.Add(TKey key, InternalEntityEntry entry, Boolean updateDuplicate)
   at Microsoft.EntityFrameworkCore.ChangeTracking.Internal.IdentityMap`1.Add(TKey key, InternalEntityEntry entry)
Code:
CREATE TABLE [dbo].[AppAssignment] (
    [ApplicationID] INT NOT NULL,
    [IndAppID]      INT NOT NULL,
    CONSTRAINT [PK_AppAssignment] PRIMARY KEY CLUSTERED ([IndAppID] ASC, [ApplicationID] ASC),
    CONSTRAINT [FK_AppAssignment_Application_ApplicationID] FOREIGN KEY ([ApplicationID]) REFERENCES [dbo].[Application] ([ID]) ON DELETE CASCADE,
    CONSTRAINT [FK_AppAssignment_IndApp_IndAppID] FOREIGN KEY ([IndAppID]) REFERENCES [dbo].[IndApp] ([ID]) ON DELETE CASCADE
GO
CREATE NONCLUSTERED INDEX [IX_AppAssignment_ApplicationID]
    ON [dbo].[AppAssignment]([ApplicationID] ASC);
Code:
using Tracker.Models;
using System;
using System.Linq;
using Microsoft.EntityFrameworkCore;
using Microsoft.Extensions.DependencyInjection;
namespace Tracker.Data
    public static class DbInitializer
        public static void Initialize(TrackerContext context)
            //context.Database.EnsureCreated();
            // Look for any students.
            if (context.Applications.Any())
                return;   // DB has been seeded
            var Applications = new Application[]
            new Application{CTXApp="FirstApp",FirstMidName="Carson",LastName="Alexander",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2005-09-01")},
            new Application{CTXApp="GCMS",FirstMidName="Meredith",LastName="Alonso",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2002-09-01")},
            new Application{CTXApp="Oracle",FirstMidName="Arturo",LastName="Anand",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2003-09-01")},
            new Application{CTXApp="Empower",FirstMidName="Gytis",LastName="Barzdukas",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2002-09-01")},
            new Application{CTXApp="TCSDesktop",FirstMidName="Yan",LastName="Li",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2002-09-01")},
            new Application{CTXApp="Documentum",FirstMidName="Peggy",LastName="Justice",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2001-09-01")},
            new Application{CTXApp="OneCDS",FirstMidName="Laura",LastName="Norman",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2003-09-01")},
            new Application{CTXApp="Access",FirstMidName="Nino",LastName="Olivetto",BusinessUnit="GMS",EnrollmentDate=DateTime.Parse("2005-09-01")}
            foreach (Application a in Applications)
                context.Applications.Add(a);
            context.SaveChanges();
            /*var IndApps = new IndApp[]
            new IndApp{IndAppID=1050,Title="Chemistry",Credits=3},
            new IndApp{IndAppID=4022,Title="Microeconomics",Credits=3},
            new IndApp{IndAppID=4041,Title="Macroeconomics",Credits=3},
            new IndApp{IndAppID=1045,Title="Calculus",Credits=4},
            new IndApp{IndAppID=3141,Title="Trigonometry",Credits=4},
            new IndApp{IndAppID=2021,Title="Composition",Credits=3},
            new IndApp{IndAppID=2042,Title="Literature",Credits=4}
            foreach (IndApp ia in IndApps)
                context.IndApps.Add(ia);
            context.SaveChanges();*/
            new IndApp{Application="Access",Version="1"},
            new IndApp{Application="Excel",Version="2"},
            new IndApp{Application="Word",Version="3"}
            var AppAssignments = new AppAssignment[]
            new AppAssignment {
                    IndAppID = IndApps.Single(ia => ia.Application == "Access" ).ID,
                    ApplicationID = Applications.Single(a => a.CTXApp == "FirstApp").ID
            new AppAssignment {
                    IndAppID = IndApps.Single(ia => ia.Application == "Excel" ).ID,
                    ApplicationID = Applications.Single(a => a.CTXApp == "GCMS").ID
            new AppAssignment {
            new AppAssignment {
                    IndAppID = IndApps.Single(ia => ia.Application == "Word" ).ID,
            new AppAssignment {
                    ApplicationID = Applications.Single(a => a.CTXApp == "Oracle").ID
            new AppAssignment {
                    ApplicationID = Applications.Single(a => a.CTXApp == "Empower").ID
            new AppAssignment {
                    ApplicationID = Applications.Single(a => a.CTXApp == "TCSDesktop").ID
            new AppAssignment {
                    ApplicationID = Applications.Single(a => a.CTXApp == "Documentum").ID
            new AppAssignment {
                    ApplicationID = Applications.Single(a => a.CTXApp == "OneCDS").ID
            new AppAssignment {
            foreach (AppAssignment aa in AppAssignments)
                context.AppAssignments.Add(aa);
            var enrollments = new Enrollment[]
            new Enrollment{ApplicationID=1,IndAppID=1050,Grade=Grade.A},
            new Enrollment{ApplicationID=1,IndAppID=4022,Grade=Grade.C},
            new Enrollment{ApplicationID=1,IndAppID=4041,Grade=Grade.B},
            new Enrollment{ApplicationID=2,IndAppID=1045,Grade=Grade.B},
            new Enrollment{ApplicationID=2,IndAppID=3141,Grade=Grade.F},
            new Enrollment{ApplicationID=2,IndAppID=2021,Grade=Grade.F},
            new Enrollment{ApplicationID=3,IndAppID=1050},
            new Enrollment{ApplicationID=4,IndAppID=1050},
            new Enrollment{ApplicationID=4,IndAppID=4022,Grade=Grade.F},
            new Enrollment{ApplicationID=5,IndAppID=4041,Grade=Grade.C},
            new Enrollment{ApplicationID=6,IndAppID=1045},
            new Enrollment{ApplicationID=7,IndAppID=3141,Grade=Grade.A}
            foreach (Enrollment e in enrollments)
                context.Enrollments.Add(e);
            context.SaveChanges(); */
Code:
using Microsoft.AspNetCore.Http;
    public class TrackerContext : DbContext
        public TrackerContext(DbContextOptions<TrackerContext> options) : base(options)
        public DbSet<IndApp> IndApps { get; set; }
        public DbSet<Enrollment> Enrollments { get; set; }
        public DbSet<Application> Applications { get; set; }
        public DbSet<AppAssignment> AppAssignments { get; set; }
        protected override void OnModelCreating(ModelBuilder modelBuilder)
            modelBuilder.Entity<IndApp>().ToTable("IndApp");
            //modelBuilder.Entity<IndApp>().ToTable("IndApp2");
            modelBuilder.Entity<Enrollment>().ToTable("Enrollment");
            modelBuilder.Entity<Application>().ToTable("Application");
            modelBuilder.Entity<AppAssignment>().ToTable("AppAssignment");
               .HasKey(c => new { c.IndAppID, c.ApplicationID });
Code:
using System;
using System.Collections.Generic;
using System.ComponentModel.DataAnnotations;
using System.ComponentModel.DataAnnotations.Schema;
namespace Tracker.Models
    public class Application
        public int ID { get; set; }
        [Required]
        [StringLength(50, MinimumLength = 1)]
        [RegularExpression(@"^[A-Z]+[a-zA-Z""'\s-]*$")]
        [Display(Name = "Citrix Application")]
        public string CTXApp { get; set; }
        [Required]
        [Display(Name = "Last Name")]
        public string LastName { get; set; }
        [Column("FirstName")]
        [Display(Name = "First Name")]
        public string FirstMidName { get; set; }
        [Required]
        [StringLength(3, MinimumLength = 1)]
        [Display(Name = "Business Unit")]
        public string BusinessUnit { get; set; }
        [DataType(DataType.Date)]
        [DisplayFormat(DataFormatString = "{0:yyyy-MM-dd}", ApplyFormatInEditMode = true)]
        public DateTime EnrollmentDate { get; set; }
        [Display(Name = "Full Name")]
        public string FullName
            get
                return LastName + ", " + FirstMidName;
        public ICollection<AppAssignment> AppAssignments { get; set; }
Code:
    public class IndApp
        [Required]
        [Display(Name = "Application")]
        public string Application { get; set; }
        [Required]
        [Display(Name = "Version")]
        public string Version { get; set; }
Code:
using System;
    public class AppAssignment
        public int ApplicationID { get; set; }
        public int IndAppID { get; set; }
        public Application Application { get; set; }
        public IndApp IndApp { get; set; }
Cheers, Paul.
You've got you're table setup correctly, the primary key is a clustered key of both ApplicationID and IndAppID fields. That means you can have duplicates in either field but not in both fields at the same time.
So the issue is this section in DbInitializer.cs which is duplicated twice:
Code:
new AppAssignment {
So next hiccup.
As per this section I'm now trying to add/remove elements.
The solution builds successfully but will throw out the following error when editing an application.
Code:
ArgumentNullException: Value cannot be null. Parameter name: source
System.Linq.Enumerable.Select<TSource, TResult>(IEnumerable<TSource> source, Func<TSource, TResult> selector)
Tracker.Controllers.ApplicationsController.PopulateAssignedAppData(Application application) in ApplicationsController.cs
179.            return View(application);
180.        }
181.
182.        private void PopulateAssignedAppData(Application application)
183.        {
184.            var allindapps = _context.IndApps;
185.            var CTXAppsApps = new HashSet<int>(application.AppAssignments.Select(c => c.IndAppID));
186.            var viewModel = new List<AssignedIndAppData>();
187.            foreach (var indApp in allindapps)
188.            {
189.                viewModel.Add(new AssignedIndAppData
190.                {
191.                    IndAppID = indApp.ID,
Tracker.Controllers.ApplicationsController.Edit(Nullable<int> id) in ApplicationsController.cs
172.            if (application == null)
173.
174.
175.            {
176.                return NotFound();
177.            }
178.            PopulateAssignedAppData(application);
180.        }
181.
183.        {
Microsoft.AspNetCore.Mvc.Internal.ActionMethodExecutor+TaskOfIActionResultExecutor.Execute(IActionResultTypeMapper mapper, ObjectMethodExecutor executor, object controller, object[] arguments)
System.Threading.Tasks.ValueTask<TResult>.get_Result()
Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeActionMethodAsync()
Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeNextActionFilterAsync()
Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Rethrow(ActionExecutedContext context)
Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.Next(ref State next, ref Scope scope, ref object state, ref bool isCompleted)
Microsoft.AspNetCore.Mvc.Internal.ControllerActionInvoker.InvokeInnerFilterAsync()
Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeNextResourceFilter()
Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Rethrow(ResourceExecutedContext context)
Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.Next(ref State next, ref Scope scope, ref object state, ref bool isCompleted)
Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeFilterPipelineAsync()
Microsoft.AspNetCore.Mvc.Internal.ResourceInvoker.InvokeAsync()
Microsoft.AspNetCore.Routing.EndpointMiddleware.Invoke(HttpContext httpContext)
Microsoft.AspNetCore.Routing.EndpointRoutingMiddleware.Invoke(HttpContext httpContext)
Microsoft.AspNetCore.StaticFiles.StaticFileMiddleware.Invoke(HttpContext context)
Microsoft.AspNetCore.Diagnostics.DeveloperExceptionPageMiddleware.Invoke(HttpContext context)
Code:
using System;
using System.Linq;
using System.Threading.Tasks;
using Microsoft.AspNetCore.Mvc;
using Microsoft.AspNetCore.Mvc.Rendering;
using Tracker.Data;
using Tracker.Models.TrackerViewModels;
namespace Tracker.Controllers
    public class ApplicationsController : Controller
        private readonly TrackerContext _context;
        public ApplicationsController(TrackerContext context)
            _context = context;
        // GET: Applications
        public async Task<IActionResult> Index(int? id, int? indappID,
            string sortOrder,
            string currentFilter,
            string searchString,
            int? pageNumber)
            ViewData["CurrentSort"] = sortOrder;
            ViewData["NameSortParm"] = String.IsNullOrEmpty(sortOrder) ? "name_desc" : "";
            ViewData["DateSortParm"] = sortOrder == "Date" ? "date_desc" : "Date";
            if (searchString != null)
                pageNumber = 1;
            else
                searchString = currentFilter;
            ViewData["CurrentFilter"] = searchString;
            var Applications = from a in _context.Applications
                               select a;
            if (!String.IsNullOrEmpty(searchString))
                Applications = Applications.Where(s => s.LastName.Contains(searchString)
                                       || s.FirstMidName.Contains(searchString));
            switch (sortOrder)
                case "name_desc":
                    Applications = Applications.OrderByDescending(a => a.LastName);
                    break;
                case "Date":
                    Applications = Applications.OrderBy(a => a.EnrollmentDate);
                    break;
                case "date_desc":
                    Applications = Applications.OrderByDescending(a => a.EnrollmentDate);
                    break;
                default:
                    Applications = Applications.OrderBy(a => a.LastName);
                    break;
            var viewModel = new ApplicationIndexData();
            viewModel.Applications = await _context.Applications
                  .Include(i => i.AppAssignments)
                    .ThenInclude(i => i.Application)
                  //      .ThenInclude(i => i.CTXApp)
                  .OrderBy(i => i.LastName)
                  .ToListAsync();
            if (id != null)
                ViewData["ApplicationID"] = id.Value;
                Application application = viewModel.Applications.Where(
                    i => i.ID == id.Value).Single();
                viewModel.IndApps = application.AppAssignments.Select(s => s.IndApp);
            if (indappID != null)
                ViewData["IndAppID"] = indappID.Value;
                //    viewModel.Enrollments = viewModel.Courses.Where(
               // x => x.IndAppID == indappID).Single().Enrollments;
            int pageSize = 10;
            return View(await PaginatedList<Application>.CreateAsync(Applications.AsNoTracking(), pageNumber ?? 1, pageSize));
        // GET: Applications/Details/5
        public async Task<IActionResult> Details(int? id)
            if (id == null)
                return NotFound();
            var Application = await _context.Applications
                .Include(a => a.AppAssignments)
                    .ThenInclude(e => e.IndApp)
                .AsNoTracking()
                .FirstOrDefaultAsync(m => m.ID == id);
            if (Application == null)
                return NotFound();
            return View(Application);
        // GET: Applications/Create
        public IActionResult Create()
            return View();
        // POST: Applications/Create
        // To protect from overposting attacks, please enable the specific properties you want to bind to, for
        // more details see http://go.microsoft.com/fwlink/?LinkId=317598.
        [HttpPost]
        [ValidateAntiForgeryToken]
        public async Task<IActionResult> Create(
            [Bind("EnrollmentDate,BusinessUnit,FirstMidName,LastName,CTXApp")] Application application)
            try
                if (ModelState.IsValid)
                    _context.Add(application);
                    await _context.SaveChangesAsync();
                    return RedirectToAction(nameof(Index));
            catch (DbUpdateException /* ex */)
                //Log the error (uncomment ex variable name and write a log.
                ModelState.AddModelError("", "Unable to save changes. " +
                    "Try again, and if the problem persists " +
                    "see your system administrator.");
        // GET: Applications/Edit/5
        public async Task<IActionResult> Edit(int? id)
            if (id == null)
                return NotFound();
            var application = await _context.Applications.FindAsync(id);
            var instructor = await _context.Applications
               // .Include(i => i.OfficeAssignment)
               .Include(i => i.AppAssignments).ThenInclude(i => i.IndApp)
                .AsNoTracking()
                return NotFound();
                    AppName = indApp.Application    ,
                    Assigned = CTXAppsApps.Contains(indApp.ID)
            ViewData["IndApps"] = viewModel;
        // POST: Applications/Edit/5
        // [HttpPost, ActionName("Edit")]
        [HttpPost]
        public async Task<IActionResult> Edit(int? id, string[] selectedIndApps)
            if (id == null)
                return NotFound();
            //var ApplicationToUpdate = await _context.Applications.FirstOrDefaultAsync(a => a.ID == id);
            if (await TryUpdateModelAsync<Application>(
                ApplicationToUpdate,
                a => a.BusinessUnit,a => a.FirstMidName, a => a.LastName, a => a.EnrollmentDate))
                UpdateApplicationIndApps(selectedIndApps, ApplicationToUpdate);
                try
                    //Log the error (uncomment ex variable name and write a log.)
                        "Try again, and if the problem persists, " +
            PopulateAssignedAppData(ApplicationToUpdate);
            return View(ApplicationToUpdate);
        private void UpdateApplicationIndApps(string[] selectedIndApps, Application ApplicationToUpdate)
            if (selectedIndApps == null)
                ApplicationToUpdate.AppAssignments = new List<AppAssignment>();
                return;
            //var selectedIndAppsHS = new HashSet<string>(selectedIndApps);
            var ApplicationIndApps = new HashSet<int>
                (ApplicationToUpdate.AppAssignments.Select(c => c.IndApp.ID));
            foreach (var indapp in _context.Applications)
                if (selectedIndAppsHS.Contains(indapp.ID.ToString()))
                    if (!ApplicationIndApps.Contains(indapp.ID))
                        ApplicationToUpdate.AppAssignments.Add(new AppAssignment { ApplicationID = ApplicationToUpdate.ID, IndAppID = indapp.ID });
                else
                    if (ApplicationIndApps.Contains(indapp.ID))
                        AppAssignment IndAppToRemove = ApplicationToUpdate.AppAssignments.FirstOrDefault(i => i.IndAppID == indapp.ID);
                        _context.Remove(IndAppToRemove);
        // GET: Applications/Delete/5
        public async Task<IActionResult> Delete(int? id, bool? saveChangesError = false)
            if (id == null)
                return NotFound();
                .AsNoTracking()
                return NotFound();
            if (saveChangesError.GetValueOrDefault())
                ViewData["ErrorMessage"] =
                    "Delete failed. Try again, and if the problem persists " +
                    "see your system administrator.";
        // POST: Applications/Delete/5
        [HttpPost, ActionName("Delete")]
        public async Task<IActionResult> DeleteConfirmed(int id)
            try
                _context.Applications.Remove(application);
                return RedirectToAction(nameof(Delete), new { id = id, saveChangesError = true });
        private bool ApplicationExists(int id)
            return _context.Applications.Any(e => e.ID == id);
Code:
@model Tracker.Models.Application
    ViewData["Title"] = "Edit";
<h1>Edit</h1>
<h4>Application</h4>
<hr />
<div class="row">
    <div class="col-md-4">
        <form asp-action="Edit">
            <div asp-validation-summary="ModelOnly" class="text-danger"></div>
            <input type="hidden" asp-for="ID" />
            <div class="form-group">
                <label asp-for="CTXApp" class="control-label"></label>
                <input asp-for="CTXApp" class="form-control" />
                <span asp-validation-for="CTXApp" class="text-danger"></span>
            </div>
                <label asp-for="LastName" class="control-label"></label>
                <input asp-for="LastName" class="form-control" />
                <span asp-validation-for="LastName" class="text-danger"></span>
            </div>
                <label asp-for="FirstMidName" class="control-label"></label>
                <input asp-for="FirstMidName" class="form-control" />
                <span asp-validation-for="FirstMidName" class="text-danger"></span>
            </div>
                <label asp-for="BusinessUnit" class="control-label"></label>
                <input asp-for="BusinessUnit" class="form-control" />
                <span asp-validation-for="BusinessUnit" class="text-danger"></span>
            </div>
                <label asp-for="EnrollmentDate" class="control-label"></label>
                <input asp-for="EnrollmentDate" class="form-control" />
                <span asp-validation-for="EnrollmentDate" class="text-danger"></span>
            </div>
                <div class="col-md-offset-2 col-md-10">
                    <table>
                        <tr>
                                int cnt = 0;
                                List<Tracker.Models.TrackerViewModels.AssignedIndAppData> indapps = ViewBag.Indapps;
                                foreach (var indapp in indapps)
                                    if (cnt++ % 3 == 0)
                                    @:</tr><tr>
                                    @:<td>
                                        <input type="checkbox"
                                               name="selectedCourses"
                                               value="@indapp.IndAppID"
                                               @(Html.Raw(indapp.Assigned ? "checked=\"checked\"" : "")) />
                                        @indapp.IndAppID @:  @indapp.AppName
                                    @:</td>
                            @:</tr>
                        </table>
                    </div>
                </div>
                    <input type="submit" value="Save" class="btn btn-primary" />
                </div>
            </form>
    </div>
</div>
<div>
    <a asp-action="Index">Back to List</a>
</div>
@section Scripts {
    @{await Html.RenderPartialAsync("_ValidationScriptsPartial");}
Any pointers; much appreciated.
Cheers, Paul.
The exception means that whatever you are calling Select() on is null. I believe you can prevent the exception by instead calling Collection?.Select() - The ?. operator will return null if the collection is null, rather than proceeding to call the Select() method.
However that only stops the exception, doesn't really help with the underlying issue of why the collection is null ;)
This line gets all of the AppAssignments which belong to application and then output the IndAppID value into your hashset.
That's all going to work fine provided you have at least 1 AppAssignment or (as you've seen from the error you're getting) it's going to crash if there arn't any.
The problem is that you're not just selecting all the AppAssignments from the AppAssignment table (you'd do _context.AppAssignments for that), you're using application.AppAssignments to get all the AppAssignments linked to the application object which you passed in. If the application object you've passed in didn't have any linked AppAssignments, that'll cause the error you're getting. Looking at the db table you posted earlier, applications with IDs between 1 and 8 don't have any linked AppAssignments
Thank you all for the replies.
I understand this simply masks the exception. I did look for examples for this but could not find the syntax Collection?.Select(), only collection_select().
Could you use the new Live Share in VS2017/19 or VS Code? Sure someone could just jump in and help out that way.
I'll have a look at thanks.
OK this makes sense. However, in this instance and following on from the CU tutorial; I would have expected it would allow for instances where the Application may not be associated with any IndApp (individual application) and visa versa.
I did recheck the table data and in this example the error still occurs when there is at least one IndApp associated with the Application.
Code:
ID    Application    Version
4    Access    1
5    Excel    2
6    Word    3
Code:
ID    LastName    FirstName    BusinessUnit    EnrollmentDate    CTXApp
9    Alexander    Carson    GMS    2005-09-01 00:00:00.0000000    FirstApp
10    Alonso    Meredith    GMS    2002-09-01 00:00:00.0000000    GCMS
11    Anand    Arturo    GMS    2003-09-01 00:00:00.0000000    Oracle
12    Barzdukas    Gytis    GMS    2002-09-01 00:00:00.0000000    Empower
13    Li    Yan    GMS    2002-09-01 00:00:00.0000000    TCSDesktop
14    Justice    Peggy    VAX    2001-09-01 00:00:00.0000000    Documentum
15    Norman    Laura    GMS    2003-09-01 00:00:00.0000000    OneCDS
Code:
ApplicationID    IndAppID
9    4
9    5
9    6
10    5
11    6
12    6
13    5
14    6
15    4
EDIT. Removed the exception.
Now on to the next challenge :) I am able to check and uncheck individual applications when editing the Applications but when saving it looks it does not make the insert/delete calls and just returns back to the Application list. No errors that I can see.
Code:
            if (id == null)
                return NotFound();
            //var application = await _context.Applications.FindAsync(id);
                .AsNoTracking()
                return NotFound();
        [HttpPost]
            if (id == null)
                return NotFound();
                i => i.CTXApp, i => i.BusinessUnit,i => i.FirstMidName, i => i.LastName, i => i.EnrollmentDate))
                try
                return;
                else
Second issue relates to use paginated lists. index.cshtml is throwing an error suggesting missing directive or Assembly reference.
Throwing the error at lines;
@foreach (var item in Model.Applications)
@if (Model.IndApps != null)
@foreach (var item in Model.IndApps)
Yet; These are included in the referenced class on the first line of the index.cshtml
@model PaginatedList<Tracker.Models.TrackerViewModels.ApplicationIndexData>
Code:
    ViewData["Title"] = "Citrix Applicatiom";
<h1>Index</h1>
<p>
    <a asp-action="Create">Create New</a>
</p>
<form asp-action="Index" method="get">
    <div class="form-actions no-color">
        <p>
            Find by name: <input type="text" name="SearchString" value="@ViewData[" currentFilter"]" />
            <input type="submit" value="Search" class="btn btn-default" /> |
            <a asp-action="Index">Back to Full List</a>
        </p>
    </div>
</form>
<table class="table">
    <thead>
        <tr>
            <th>
                <a asp-action="Index" asp-route-sortOrder="@ViewData["NameSortParm"]" asp-route-currentFilter="@ViewData["CurrentFilter"]">CTXApp</a>
            </th>
            <th>
                <a asp-action="Index" asp-route-sortOrder="@ViewData["NameSortParm"]" asp-route-currentFilter="@ViewData["CurrentFilter"]">Last Name</a>
            </th>
            <th>
                First Name
            </th>
            <th>
                Business Unit
            </th>
            <th>
                <a asp-action="Index" asp-route-sortOrder="@ViewData[" DateSortParm"]" asp-route-currentFilter="@ViewData[" CurrentFilter"]">Enrollment Date</a>
            </th>
            <th>
                Application
            </th>
            <th></th>
        </tr>
    </thead>
    <tbody>
            string selectedRow = "";
            if (item.ID == (int?)ViewData["ApplicationID"])
                selectedRow = "success";
            <tr class="@selectedRow">
                <td>
                    @Html.DisplayFor(modelItem => item.CTXApp)
                </td>
                <td>
                    @Html.DisplayFor(modelItem => item.LastName)
                </td>
                <td>
                    @Html.DisplayFor(modelItem => item.FirstMidName)
                </td>
                <td>
                    @Html.DisplayFor(modelItem => item.BusinessUnit)
                </td>
                <td>
                    @Html.DisplayFor(modelItem => item.EnrollmentDate)
                </td>
                <td>
                        foreach (var indapp in item.AppAssignments)
                            @indapp.IndApp.ID @:  @indapp.IndApp.Application <br />
                </td>
                <td>
                    <a asp-action="Index" asp-route-id="@item.ID">Select</a> |
                    <a asp-action="Edit" asp-route-id="@item.ID">Edit</a> |
                    <a asp-action="Details" asp-route-id="@item.ID">Details</a> |
                    <a asp-action="Delete" asp-route-id="@item.ID">Delete</a>
                </td>
            </tr>
    </tbody>
</table>
    <h3>Applications presented to solution.</h3>
        <tr>
            <th></th>
            <th>ID</th>
            <th>Application</th>
            <th>Version</th>
        </tr>
            if (item.ID == (int?)ViewData["CourseID"])
                <td>
                    @Html.ActionLink("Select", "Index", new { indappID = item.ID })
                </td>
                <td>
                    @item.ID
                </td>
                <td>
                    @item.Application
                </td>
                <td>
                    @item.Version
                </td>
            </tr>
    </table>
        var prevDisabled = !Model.HasPreviousPage ? "disabled" : "";
        var nextDisabled = !Model.HasNextPage ? "disabled" : "";
       asp-route-sortOrder="@ViewData[" CurrentSort"]"
       asp-route-pageNumber="@(Model.PageIndex - 1)"
       class="btn btn-default @prevDisabled">
        Previous
    </a>
       asp-route-pageNumber="@(Model.PageIndex + 1)"
       class="btn btn-default @nextDisabled">
        Next
    </a>
Code:
using System;
using System.Linq;
namespace Tracker.Models.TrackerViewModels
    public class ApplicationIndexData
        public IEnumerable<Application> Applications { get; set; }
        public IEnumerable<IndApp> IndApps { get; set; }
