C Max Owners - A question...
19 Jan 2010
Now this may be only on the early Focus C Max models, but I am not sure.
Looking from the rear passenger seats between the two front seats is the centre console (where you used to keep your tapes in the olden days), facing the rear passengers are two (one above the other) little compartments where you may/used to find a rear ashtray and/or 12v socket.
How do you open the top one? Should it be spring loaded? As it appears, on one we just went to look at, that you had to push it at the bottom to make it pop out at the top. I am just interested in knowing if it's that way, or if it's broke.
Cheers.
