I've put Application.EnableVisualStyles(); in the main form before Application.Run();, but it's still looking exactly as it was before. I don't know if it makes a difference that the form with the buttons on is a different one to the startup form?
Have you set the FlatStyle of all the controls on your form to FlatStyle.System?
This, in addition to Application.EnableVisualStyles() will do the job, nothing else is needed
