Say i have a class called CustomModule1 which inherits from an abstract base class called Module.
All 'CustomModules' will be in thier own dll and my main application will load them from a folder at run time.
At this point i wish to store information about the CustomModules by getting their string ModuleName (with is different for each module) without creating an instance of the module (statically).
I can't think of away todo this, as I'm loading the CustomModules as Module types, so the static string ModuleName will have to be defined in the ModuleClass.
I need the CustomModule to override this static variable so it gives its own unique name, but you cannot override static properties or methods.
Any thoughts?
Any thoughts?
