I've got two globally declared strings:
I set the locations string first by filling it with data from a txt file using: (temp being a local string declared like char temp[25])
I then set the speedSting using
When setting the speedString, not only does it fill the speedString (correctly) but it also overwrites parts of the locations string.
Any ideas as to why this is happening? It's really doing my head in because I cant see why it is doing it. There are other functions before and after this problem area setting strings fine
Thanks for any help.
Code:
char locations[5][25];
char speedString[25];
Code:
locations[count][end] = temp[end];
Code:
sprintf (speedString, "Speed: %3d kmh", curSpeed);
