C++ question regarding classes, inheritence
26 Jun 2003
North West
Ive recently seen a bit of code, cant remember excally what is was but it went sumthing like this:
class MyClass1 {
// stuff
class MyClass2 : public MyClass1 {
// stuff
Now to declare an object of these, I thought the way you did it was like this:
MyClass1 myClass1;
MyClass1 *myClass1 = new MyClass1;
MyClass2 myClass2 = new MyClass2;
etc.
But I saw it declared like this:
MyClass2 *myClass2 = new MyClass1;
or
MyClass1 *myClass1 = new MyClass2;
(can both be used?)
As you can see its declared MyClass2 but called new MyClass1?
(Similar to doing: int myInt = new String, i know bad example but this is what it seems like).
Can someone clarify how this works?
Thx
Not done any C++ in a while but if I remember rightly you can create a child class but make it the parent class type
so..
MyClass2 *foo = new MyClass1
should be perfectly OK, but I'm not sure if you can do it the other way round...
class MyClass1 {
// stuff
// stuff
MyClass1 myClass1;
etc.
or
(can both be used?)
Thx
Since class2 is derived from class1, a class1 pointer can be used to refer to a class2 object, but not vice versa.
Its easier to explain using classes called Base and Derived:
Code:
class Base{
// stuff
class Derived: public Base{
// stuff
Base base; // Fine - creates an instance of Base called base on the stack
Base*myBase= new Base; // Fine - creates a Base pointer to a Base object
Derived * myDerived = new Derived; // Fine - a Derived pointer to a Derived object
Derived * myClass2 = new Base; // ERROR: A Derived pointer cannot point to a Base object
Base*myClass1 = new Derived; //FINE - this is a Base pointer to a derived object
Any subclass can always be stored in a variable that is of that class' superclass.
You can't store a superclass into a variable declared as a subclass of that superclass because the subclass is more specialised than the superclass.
ie Subclass is a type of Superclass but the Superclass is never a type of one of its subclasses.
(afaik)
Thanks a lot for your explanations. They helped.
So if I get this right, regarding virtual and inheritence:
class Base
public:
vurtual void functionA(int x);
void functionB(int x);
class Derived : public Base
public:
BaseClass *base = new Derived;
base->functionA(1); // This will call derived's functionA?
base->functionB(1); // This will call base's functionB because functionB is not vurtual?
Thx
I just used my brain and wrote this program to test. Works fine and I now understand it.
Thx for your help.
Code:
#include <iostream>
using namespace std;
class Base
	public:
		virtual void functionA() { cout << "Base FunctionA" << endl; }
		        void functionB() { cout << "Base FunctionB" << endl; }
	public:
		void functionA() { cout << "Derived FunctionA" << endl;}
		void functionB() { cout << "Derived FunctionB" << endl;}
int main()
	Base *base = new Derived;
	base->functionA(); // Calls derived functionA
	base->functionB(); // Calls base functionB
	return 0;
