6 Jun 2006 at 18:21 #1 J1234 J1234 Soldato Joined 16 Oct 2005 Posts 13,791 Would just one of these be enough to run a GPU and CPU block water cooling system; using a 120.1 rad and 5 1/4" DD bay res?
6 Jun 2006 at 18:33 #2 DaveMac DaveMac Soldato Joined 26 May 2004 Posts 3,013 Location Wolves Yes and very well if the blocks are not very restrictive, ie maze 4. A larger rad would bring lower temps with less fan power(noise), depending what you are cooling.
6 Jun 2006 at 19:25 #3 welshtom welshtom Permabanned Joined 17 Aug 2004 Posts 3,462 Location Pencoed I've used a nexxos with these pumps and had good temps, with a mp-1 in the loop too
