- 16 Nov 2003
- On the pale blue dot
Hi guys.
I need to read 400+ files from the Internet which of course takes time, most of which is latency requesting the file as they are very small files. Therefore I want to dabble in threading to say do 10 simultaneous requests at once.
The difficult part is that I read the files into a hashtable which is processed further down the line, but threads do not return values so I can't execute 10 threads that read into the same hashtable, not to mention 10 threads trying to access the same variable at the same time is likely to cause some very nasty problems.
I'm a bit stumped on how to proceed. Has anyone done anything similar in the past, how can I collate the data the separate threads generate into one source?
