C++ vs Visual C++
10 Oct 2005
London
Can someone explain to me the difference between C++ and Visual C++, which one is standard etc
How similar are they, will programs coded in one run in the other?
Visual C++ (AKA MSVC) refers to either the Microsoft application you can use to write C++ or the compiler that that program uses under the hood.
There are other C++ compilers, such as GCC.
C++ itself is a standard (ISO <somenumber>) which each compiler implements to some degree of accuracy (and probably adds some of their own extensions for good measure).
It's probably not worth worrying about if you are just starting out.
Yeah its just the ide, and it isnt even very visual either. Its nothing special just a trick to convince everyone that they've got something special.
The 'visual' part refers to the fact that you can make a GUI using a wysiwyg interface. The C++ means it uses that language rather than Basic, C# etc.
