- 3 Dec 2003
- Sunderland
I finally decided that my XPM system is getting too slow for me, also with the ASrock board with DDR1 ram and AGP support, I can finally afford to upgrade.
With this upgrade, I'm going to be using my 2x512 Geil BH5 ram which should give me enough fsb with the Asrock board. I also have a very good watercooling setup (stormG4, D4 pump with 2 nova rads in a rad box) so cooling wouldn't be a problem.
I need some advice because I'm a bit new with the whole C2D. I want to get a chip with the best future overclocking ability because I will eventually change to a proper board which won't be limited by fsb. With my budget, I can afford either a 4400, 6300 or 6320.
I know that the 6320 has 4mb cache when the 6300 and 4400 has 2. However, I don't understand the difference between the 4400 and 6300 except for the higher stock fsb but I remember someone said the 6300 will be better when I change to a good board so I am a bit confused here.
I know the 4400 will give me the best overclock for now because of the higher stock multiplier, but which one of these will give me the best performance when I change to a good board in the furture?
