Howdy,
When I st built this PC I noticed that my Core 2 Duo would throttle back when not doing much. Now it is constantly @ 2.4Ghz, so I think Speedstep is not working. I have reset my BIOS to default values, and no change in CPU speed.
I know that XP has built in support for speedstep (or am I wrong and need a driver?)
Also my CPU fan is spinning a lot faster then it used to. I noticed this after I installed an 8800GTS. I thought the fan noise was from that, but it is the CPU fan.
Both cores are at 40 degrees C, so why is the fan at 2700RPM?
CPU cooler is this one https://www.overclockers.co.uk/showproduct.php?prodid=HS-020-ZA
(Zalman CNPS9500-AT CPU Cooler), MB is ASUS P5B Deluxe. CPU is C2D 6600.
The only thing I can think of is that when I installed the 8800GTS i knocked the CPU cooler, but if it was not seated correctly, my temps would be higher?
Any ideas?
Ta.
Any ideas?
Ta.
