Hi, ive had this E6600 for a while now, and while initially i fiddled a bit with ocing, i had so much trouble getting the system to run on Win2K (which i failed to do) and eventually managed to get it running on XP (after a lot of messing about) that ive forgotten what all the temps stuff means. So, Assuming system is stock:-
What should my Tcase be at idle/load
What should my cores be at idle/load
What should PECI be set to in bios
chrs
chrs
