4 Apr 2007 at 16:51 #1 A[L]C A[L]C Soldato Joined 18 Oct 2002 Posts 7,514 Location Maidenhead Hi all, Ive got some PC2-4300 ram here. Is this stuff suitable for use with the C2D? Ta
4 Apr 2007 at 16:53 #2 furnace furnace Soldato Joined 12 Dec 2006 Posts 3,421 Location Worthing, West Sussex It's OK if you're sticking to stock speeds, but if you want to overclock at all then you really should get some 800Mhz ram (PC 6400).
4 Apr 2007 at 16:56 #3 A[L]C A[L]C Soldato OP Joined 18 Oct 2002 Posts 7,514 Location Maidenhead Just looking for a cheap upgrade atm. Currently got a A64 3000+ @ 2.26ghz, 2gb ram (horrible config of 4x512mb), X800GTO2. Might just get an X2 3800+ thinking about it. Hmmmm...
