I've got a Q9550 (C1 sadly), Gigabyte EP45-UD3L and 4GB (2x2) PC2-6400 XMS2 RAM.
Now, as I understand it the overclocking will work as follows for example:
333x8.5 = 2830MHz, RAM @ 667MHz (stock)
400x8.5 = 3400MHz, RAM @ 800MHz (good spot for the RAM)
450x8.5 = 3825MHz, RAM @ 900MHz (not so good for 800MHz RAM)
Looking around, I can only find talk of using dividers to make the RAM run faster than the FSB relatively, whereas on my A64 machine, it made it slower.
Will I be able to set the RAM divider up so that it was at say 4:5 (450MHz FSB + 360/720MHz RAM), rather than the 5:4 (450MHz FSB + 562/1125MHz) I keep seeing?
Or will I just have to cry and contemplate buying some PC2-8500 instead at some point if I want to go much beyond 3.4GHz?
