But it's apparently FreeSync 2, so it should have FRC by default (which means you don't have to worry that much about the minimum range).
Aah, yes. I mistakenly remembered it as FrameRate Compensation, so forgot the L.You meant LFC (low framerate compensation) rather than FRC (Frame Rate Control - a technique for increasing colour gamut by temporal dithering).
For your information you can also use CRU to edit freesync ranges.
https://www.monitortests.com/forum/Thread-Custom-Resolution-Utility-CRU
Aah, yes. I mistakenly remembered it as FrameRate Compensation, so forgot the L.![]()
If the FreeSync range is 80~120, I will not buy this monitor...
I want to buy a monitor with HDR, 1440P, 144hz, IPS (FreeSync or G-Sync)
... the 60-80fps range would apparently fall outside FreeSync operation, as it isn't directly inside the FS range, and can't be multiplied to it, either.
Before purchasing a monitor with such a range, you should probably consult the manufacturer, first.
But 2x 80 would still be 160Hz, so even that is not enough.
