C700P RGB lighting advice
27 Sep 2013
I've ordered a c700p, was hoping to add a RGB strip seems the cooler master RGB strips are no longer available. I was wondering what strips or if all rgb strips work with the c700p onboard controller? My mobo doesn't do RGB so would be nice to have the internal lighting linked with the external of the case. I also presume a rgb splitter can be used to add more then one if needed. Thanks for your help
