Cable Braiding help
18 Dec 2009
Hi Guys ,
New to this , and my first attempt, I want to braid my 24pin and 6 pin PCI cable but i dont know what size braid and heat shrink i need for this? I also want to braid my Sata cables , Fan cables ( single braid ) connector cables ( single braid ) Can anyone advise please
Many Thanks
Dog09
Braid is measured with nominal diameter. For fan cables 4mm would be good, paired with 3.2mm heatshrink (2:1 ratio). For larger cables, work out the diameter and buy accordingly.
I used 4mm sleeving for all my PSU cables and fans with 4.5mm 3:1 ratio adhesive lined heatshrink.
I've tried using the non adhesive stuff but I found it was pretty poor compared to adhesive lined heatshrink.
::edit::
This was sleeving the wires individually, for my SATA data cables I used 10mm sleeving with 12mm shrink.
4mm braid for psu/fan cables with 5mm heat shrink (2:1) is what i went with. as for sata cables think i used 10mm braid with 15mm heat-shrink (3:1). or you could just do as stated above and get some NZXT pre-braided cables :D, good luck.
Not sure what size you need tbh.
You should check these out though.
Pre braided cables
I would say that this is cheating but only because I only noticed it on the site the day I started braiding my PSU the old fashioned way :D
Anyway to answer the question - I would generally just go for the smallest braiding available to you for the individual cables - they are really small and thicker braiding would make your job harder.
I used 4:1 heatshrink with small braid for individual wires and 3:1 for the SATA.
For black sata cables, i was fortunate enough to have quite a few left over from a dead evga 680i board, same for molex to 2 x sata connectors, about the only good thing about that board.
